Capturing the number of pages from Metadata from create print content
I have a simple workflow which takes in a CSV file runs through a data mapper etc to finally output a pdf into a folder (output to workflow rather than the output presets. i can capture the number of documents from the Meta data in a traditional PP way but this isn’t there even after the create job element so i can’t build a report. please help
The metadata after Create Job should still be there, I’ve been using that for a couple of things. Unfortunately, the current number of physical pages in the document/group/job is not currently reflecting the reality of what the output is actually producing, so getting a number of pages is not possible this way unless you’re not doing any overflow or conditional contents.
A workaround would be to use the Metadata tools on the PDF output, since the metadata tools can be used directly on PDF without using a PlanetPress 7 Document.
