When defying an output preset mask the documentation shows several possibilities Variables available in the Output
Specifically the padding of numbers works fine when using connect built-in variables like ${file.nr,000}, but fails when using user defined ones like ${set.metadata.IDPLICO,000}.
From the Job Preset where the IDPLICO metadata field is first added to the document set metadata fields there is no possibility to specify the value type. From the error, I assume that every metadata field is treated like a string.
I could pad the variable from the datamapper, however, I need to use it not padded in the template and pad it only in the filename. So I would need to duplicate the record property, which is undesirable.
There was an error initiating to the output creation process caused by ApplicationException: cannot format value of class ‘java.lang.String’ at line 1, column 43 in pattern ‘${set.metadata.JOB}${set.metadata.JOB}_${set.metadata.IDPLICO,000}.pdf’
ERROR [21 Feb 2024 11:41:27,867][Worker-17: Printing via the Print Server] com.objectiflune.application.designer.editors.operations.PrintServerOperation.a(PrintServerOperation.java:-1) An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the output creation process caused by There was an error initiating to the output creation process caused by ApplicationException: cannot format value of class 'java.lang.String' at line 1, column 43 in pattern '${set.metadata.JOB}\${set.metadata.JOB}_${set.metadata.IDPLICO,000}.pdf' (SRV000041) (SRV000001)
com.objectiflune.core.base.ApplicationException: An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the output creation process caused by There was an error initiating to the output creation process caused by ApplicationException: cannot format value of class 'java.lang.String' at line 1, column 43 in pattern '${set.metadata.JOB}\${set.metadata.JOB}_${set.metadata.IDPLICO,000}.pdf' (SRV000041) (SRV000001)
at com.objectiflune.core.rest.clients.BaseRestClient.checkResponse(BaseRestClient.java)
at com.objectiflune.core.rest.clients.AuthenticatingBaseClient.invokePOST(AuthenticatingBaseClient.java)
at com.objectiflune.core.rest.clients.BaseRestClient.invokePOST(BaseRestClient.java)
at com.objectiflune.core.rest.clients.AllInOnePrintRestClient.invokePOST(AllInOnePrintRestClient.java)
at com.objectiflune.core.rest.clients.AllInOnePrintRestClient.execute(AllInOnePrintRestClient.java)
at com.objectiflune.application.designer.editors.operations.PrintServerOperation.a(PrintServerOperation.java)
at com.objectiflune.application.designer.editors.operations.d.run(d.java)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: javax.ws.rs.WebApplicationException: HTTP 500 Internal Server Error
... 8 more
