Cannot sort metadata. Field: '_vger_fld_SortOrder' is not numeric in item 0
I’m getting this error when using the Metadata Sorter task with the Numeric sorting (which is required) checkbox ticked
Cannot sort metadata. Field: ‘_vger_fld_SortOrder’ is not numeric in item 0
The field indicated only contains numeric values, so I’m unsure why this is happening?
Please disregard my question, I found the answer. In my Excel Lookup I had and action to add a field rather than replace!
I am receiving this error now, if I take off numeric sorting in metadata sorter it runs ok, but then it doesn’t sort it correctly. Any ideas why this isn’t working?
Hi @marrd,
Are you sure that all the available SortOrder fields does have a numeric value? Because I’m able to reproduce the reported error message when:
  • I assign a string value to the SortOrder field, for example: “Hello World!”
  • And when I assign no value to the SortOrder field at all
The error message I got:
[0005] W3001 : Error while executing plugin: Cannot sort metadata. Field: "SortOrder" is not numeric in item 0
Hi Marten
There is 105 records in total and I have looked at the metadata of each record and I can confirm that all values are numeric and that none of them are null.
I should mention that I’m assigning the value to the SortOrder field using the excel lookup method
I have done it this way in the past without a problem
Hi @marrd,
I suppose that at this point it will probably be better to open a technical support ticket via our website because I assume that we need to have a look at the Excel lookup.
