Can sprintf or vsprintf be installed with connect?
If so how do we install it for designer and work flow?
Glenn,
You can most definitely install something like sprintf-js (which is both sprintf and vsprintf) and use it, as with any other JavaScript library in Designer. However, it might not be necessary - Connect already offers a full formatting suite for all the data types we support (date, currency, etc). When you add a Text Script, you simply need to use the “Format” column to choose the formatting. As for the language, it uses the settings found in Edit -> Locale.
Some references:
http://help.objectiflune.com/en/planetpress-connect-user-guide/1.3/designer/script_edit_text.htm
~Evie
How do we install sprintf-js in designer? And then would it need to be installed on the watch server as well?
I see several different methods to install, but not sure which one connect would need.
