how could i do this?
thanks
Check the answers on the following post, I believe you are trying to achieve the same:
What I need is that I do not take the blank spaces, I mean the br above
Do you mean the two empty lines at the beginning of your data?
yes Erik, it is have a need.
I believe you could achieve that by adding a Goto step to your data map and set the Target type to ‘Next line with content’.
thanks i have solved the problem.
