I have a document template where the last element on the page ends within the defined mrgins. However, it appears to be generating a 2nd page that is blank. How do I eliminate this page?
Hi JR,
Backup your template first before reading further.
I get the same thing at times. The only way I could figure it out was to look at the source and delete some code in there. In my case there was a bunch of “<br></br>” in the source. After deleting the second page went away. Be very careful of editing or modifying the source code of you template. Always backup first.
Perhaps wait till one of the pro’s here answer with a more detailed solution.
I did find the cause and corrected it. When adding the common information on teh Master page I did not have it properly selected so it was added to section 1. After deleting it I was able to see the extra paragraphs at the end. Typical user error.
Thanks!
