Barcodes in tables
I have a customer requiring a packing slip with the quantity, item, PO number, etc each with their own barcode on each line. So I’ll have multiple lines, and each line will have 3 barcodes in it.
Is there a fairly simple way to do this?
I was hoping to just put them in a table and barcode each value.
Or is there some way to do this with a script?
It should be possible to use a table and add a barcode to each table cell.
Did you already try that?
Well yes and no. I did get support. Here’s the solution, for the record.
To get it to work, a div needs to be in the , as well as a selector script.
script selector #PoNumBarcode
