Hello, I use automatic saving during my projects, in the original directory. But sometimes I get a little lost with these OL-template extensions. Would it be possible to add an option in this window, with registration OL-template.bak for example. Note that we do not use the Other directory option because we change directories for each client. Thanks
You really should be using Project Versioning for this. The GIT integration allows you to go backward/forward in the history of your resources and make sure they are saved in separate folders.
Thank you, it’s a good solution for our software usage
