attachement local file vs remote file
In workflow:
Adding an attachment to a e-mail in the form of [\servername\sharex\123.pdf](file://\servername\sharex\123.pdf) does not work for me (i get a mail without attachement)
If i do the same thing with a fille stored localy: c:\123.pdf i do recieve a correct mail with attachement.
If i simulate this in Designer (on the same server as Workflow) with the same data ([\servername\sharex\123.pdf](file://\servername\sharex\123.pdf)) i also get an email with the desired attachement.
Any help would be appreciated
Which plugin are you using the send email? The Send Email output plugin or the Create Email Content Connect plugin?
I do this with Create Email Content
Try using the file:// protocol and set the path to:
file://servername/sharex/123.pdf
In addition, take a look at the following two links for more detailed information:
http://learn.objectiflune.com/en-us/planetpress-connect/howto/internal-external-and-web-resources
http://learn.objectiflune.com/en-us/planetpress-connect/howto/add-custom-email-attachments
Thanks,
Tried using the file:// option, but the results were the same (local file ok remote file not).
Looking at the Workflow server, i found a service that used the local account (OL connect server).
Changing this to domain account resolved the issue. i now can use [\server\share\filename](file://\server\share\filename)
as attachements
on a local computer it is “file:///c:/folder/filename.docx” but on a server it looks odd but this will work: “file://///servername/shared-folder/filename.docx”. 5 slashes is needed.
