Apply master page to only the first page
I have a print section where it has dynamic data that could push the section to be 2 or more pages based on 2 detail tables from the data model. Because of this, I am having an issue where if I use a master page to control my header and footer it is applied to all pages. Is there a way to only have the master page applied to the first page. Secondly can I have different pages use different master pages. For Instance, the first pages needs a header and footer, the second page only needs a header. If I setup 2 different master pages can I switch between them?
The option you’re looking for is in Sheet Configuration on the Print Section. Uncheck ‘Same for all positions’ and you’ll be able to select which masterpage gets used for different parts of the document.
http://help.objectiflune.com/EN/planetpress-connect-user-guide/1.6/#designer/Interface/Dialog_Sheet_Configuration.htm
You may also find this helpful: https://learn.objectiflune.com/en-us/planetpress-connect/howto/overflow-with-multiple-master-pages
