Hi All
So I am having problems stapling an AFP job in designer . I was hoping someone out there has a solution.
I need to be able to staple multiple sections together , the sections are dynamically turned on and off . If I set a section to staple it works as required , but when using an output preset it does not staple.
If I use the option in the rules part of job preset , override finishing .
Thers is an open ticket for this but was hoping someone else using AFP has solved this problem .
Mark
