Add something to a .ps output
Hi everyone,
I want to add something like barrecode on a print capture .ps. I create a data mapper on the print to extract some fields. After that I created template that use this data mapper’s fields, it’s work fine but I don’t see in the template background my original ,ps used in the data mapper. I want also that the background will be the one use with the data mapper. Then need to be dynamic. Is it clear enought ?
I’m a little neww with OL and still learn !
Thanks in addanced
Right-click on your Section in the Template. Select Background…. Next, in the PDF drop-down list, select From PDF DataMapper Input.
That should do it.
Documentation on this here
That’s it. Thank you very much !
