How to access the data model data records using javascript? I need to use .filter() from javascript. The script section is not helping and some of the javascript function cannot be used.
Hi azri.shukor,
I assume you want to filter data upon generating output. Is that correct? In that scenario you could create a Job Preset configuration and enable the data filtering. Have a look at the following page:
https://help.uplandsoftware.com/objectiflune/en/pres_connect/2022.2/designer/Output/Print/Interface/Data_Filtering_Options_page.html
