Hi All,
Just updated our development/test/acceptance servers to 2023.1. Since the update we are experiencing 2 error that occur often in a run of creating 10k documents through workflow. The update is on the machines now for a couple of weeks. Backups are deleted because all seemed fine.
The errors we encounter are the following:
- ERROR: 10:27:46.172 [0061] W3685 : Error processing file E:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\36.tmp\job010HQDMYBALNXB8E4419.dat: W3687 : Error replacing job file by processed file: Error code 14007: The requested lookup key was not found in any active activation context.
- ERROR: 10:28:33.298 [0001] W3011 : Input folder error: A call to an OS function failed
So far I’ve tried te following actions:
- Check antivirus exclusions, they are fine;
- Made sure the machine is not working at full capacity;
- Reinstalling Connect after deinstallation and removal of user settings and every possible folder;
- Reinstalling Connect 2022.2 with same procedure;
- Rollback config to current production config;
All to no avail.
We have encountered this error last year on our production/acceptance/development servers, the solution then was to setup new servers for acceptance/development and do a backup restore for production.
Now I’m facing the same issue, and should setup 3 new servers for this issue. Not looking forward to do so…
What are other options to tackle this problem, and possible solutions.
Kind regards,
Ted van Roon
Nedasco BV
