Good morning.
I did not find a problem report similar to ours in the history.
Below I include the problem LOG and the Workflow schema image.
Doing tests directly in Connect Designer, with the same application used in Workflow, the error DOES NOT APPEAR. The email is sent with images, variable texts and a dynamic attachment (PDF). When executed within the Workflow, it displays the error code
[0003] W3001 : Error while executing plugin: HTTP/1.1 400 Section not found (Content).!
LOG:
Iniciar debugging.
Using schedule for SendEmail
WPROC: SendEmail (thread id: 8604) - 11:45:14
[0002] Starting plugin Executar Data Mapping - 11:45:17
[0002] Default Server IP address: localhost
[0002] Parsed Default Server IP address: localhost
[0002] Default Server Port: 9340
[0002] Parsed Default Server Port: 9340
[0002] Default Username: planetpress
[0002] Default Parsed username: planetpress
[0002] Sending file data source…
[0002] File Data Source ID: 4264
[0002] Sending data mapping command…
[0002] Using cached configuration file (id = 4261).
[0002] Starting data mapping operation…
[0002] [2023-07-07 11:45:17.808] Record creation> Retrieving results
[0002] [2023-07-07 11:45:18.121] Record creation> Generating metadata
[0002] Metadata file saved
[0002] Data successfully created from : Atas convoc cartas auxiliadora SP.OL-datamapper
[0002] Plugin Executar Data Mapping completed successfully - 11:45:18 (elapsed time: 00:00:00.771)
[0003] Starting plugin Criar Conteúdo de E-mail - 11:45:22
[0003] Default Server IP address: localhost
[0003] Parsed Default Server IP address: localhost
[0003] Default Server Port: 9340
[0003] Parsed Default Server Port: 9340
[0003] Default Username: olc-user
[0003] Default Parsed username: olc-user
[0003] Sender Address: ti.rs@soio.com.br
[0003] Parsed Sender Address: ti.rs@soio.com.br
[0003] Mail Host: smtp1.iagentesmtp.com.br
[0003] Parsed Mail Host: smtp1.iagentesmtp.com.br
[0003] Username: ti@postalmkt.com.br
[0003] Parsed Username: ti@postalmkt.com.br
[0003] Default Sender: ti.rs@soio.com.br
[0003] Parsed Default Sender: ti.rs@soio.com.br
[0003] Default Mail host: smtp1.iagentesmtp.com.br
[0003] Default Parsed mail host: smtp1.iagentesmtp.com.br
[0003] Default Username: ti@postalmkt.com.br
[0003] Default Parsed username: ti@postalmkt.com.br
[0003] Section: Conteúdo
[0003] Parsed Section: Conteúdo
[0003] Records updated from metadata
[0003] Using cached config file (id = 4263).
[0003] Starting content creation operation…
[0003] [2023-07-07 11:45:22.891] Email content creation> Retrieving results
[0003] Cached version not available, attempting to upload file.
[0003] Template C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\OLConnect\Template\envio_email.OL-template uploaded to server
[0003] [2023-07-07 11:45:23.441] Email content creation> Retrieving results
[0003] W3001 : Error while executing plugin: HTTP/1.1 400 Section not found (Conte?do)
[0003] 1: testeeeeeeee
[0003] Store ID “1” in variable “%1”
[0003] Store Message “testeeeeeeee” in variable “%1”
[0003] Criar Conteúdo de E-mail: W1603 : Plugin failed - 11:45:23 (elapsed time: 00:00:01.126)
Favor aguardar enquanto a tarefa atual termina de ser processada…
[0004] W1602 : Stopping execution of process
WPROC: SendEmail (thread id: 8604) complete - 12:02:17 (elapsed time: 00:17:02.981)
Iniciar debugging.
WPROC: SendEmail (thread id: 4736) - 12:02:22
[0002] Starting plugin Executar Data Mapping - 12:02:24
[0002] File Data Source ID: 4266
[0002] [2023-07-07 12:02:25.028] Record creation> Retrieving results
[0002] [2023-07-07 12:02:25.194] Record creation> Generating metadata
[0002] Plugin Executar Data Mapping completed successfully - 12:02:25 (elapsed time: 00:00:00.395)
[0003] Starting plugin Criar Conteúdo de E-mail - 12:02:29
[0003] Using cached config file (id = 4265).
[0003] [2023-07-07 12:02:29.817] Email content creation> Retrieving results
[0003] [2023-07-07 12:02:30.286] Email content creation> Retrieving results
[0003] Criar Conteúdo de E-mail: W1603 : Plugin failed - 12:02:30 (elapsed time: 00:00:00.986)
[0004] Starting plugin Excluir - 12:02:34
[0004] Deleting file : debugFC24EC7.dat, size: 11196 bytes
[0004] Plugin Excluir completed successfully - 12:02:34 (elapsed time: 00:00:00.001)
WPROC: SendEmail (thread id: 4736) complete - 12:02:35 (elapsed time: 00:00:12.357)
