XML Datamapping
Hello;
xml internal structure
As you can see below, there are multiple jobs in XML.
“Input Data”
When you select the ExamResultDocuments item, xmli sees it as a single job and prints a single page.
If I choose ExamResultDocumenti, I just print ExamResultDocument.
In a single Datamapper job
I need to prepare them separately like ExamResul Doucuments, SuccessDocument, ImprovementDocumnet, ClassReport and Insert.
How is PP8 with this PlanetPress 7 Suit possible?
Not sure I understand the end goal here. Are you trying to loop through each type of node to extract each type of record in their own detail table in such a way that for instance you would have 14 records for ExamResultDocument, 1 for Success Document, 9 for ImprovementDocument,…ectIs that right?
If that’s the case, then you need to use the Repeat step to loop through each Collection type. How this is done is explained in this video demo: https://learn.objectiflune.com/videos/extracting-xml-data-source/
I have also attached an example here based on your XML structure. The example was created on the latest version of Connect (v2018.1.3 at the time of writing). So you need to have at least this version to be able to open it.
yes I do this, but when I want to print the generated tamplett a single page is output.
should be 14 ExamResultDocument, 1 SuccesDocument 9 for ImprovementDocument
In the Designer template you then need to create a Detail Table. To insert a detail table click on the Insert > Table > Detail in the Connect Designer menu bar.
This demo video on Standard and Dynamic Tables here explains how to do this (skip to min 5:03)
In you case, you will need to create 3 separate detail tables in the the Designer, one for each collection type.
If you haven’t already done so, I strongly recommend that you enrol in a PlanetPress Connect course to be able to use the software with much ease. Please contact your account manager\ reseller to find out how.
I think I misrepresented what I wanted to do
when receiving print
The wrong one
must be
but it only outputs ExamResultDocument
pdf 14 requires ExamResultDocument, 1 SuccesDocument 9 for DevelopmentDocument
English:
I can see you speak Turkish, is that right? I recommend that you open a Technical Support Ticket from the following link and then send your template and example data file. A support technician will then be able to gather more information and assist you in your project.
http://planetpress.objectiflune.com/en/resources/support
Türkçe:
Türkçe konu?abilece?inizi görebiliyorum, do?ru mu? A?a??daki ba?lant?dan bir Teknik Destek Bileti açman?z? ve ard?ndan ?ablonunuzu ve örnek veri dosyan?z? göndermenizi tavsiye ederim. Bir destek mühendisi daha fazla bilgi toplayabilir ve projenize yard?mc? olabilir.
