Hi - has anyone had an issue where you had a workflow working for over a year then suddenly it doesn’t. I ran it in August and everything was fine. I ran it last week and it isn’t working. No changes to workflow either. I run it through debug and it seems to work fine. By working, I mean I get a .pdf output size 1kb ( not valid pdf). If i run it through debug, the pdf is fine.
Any suggestions?
Thank you!
UPDATE - Prior to posting tis - I ran five xml files. All pdf’s output were bad. Then after, I ran one xml file through and it was a good pdf. Then I ran three and pdf’s were good. Then I ran all 25 files through again and the output pdf’s are all good.
While it seems to be working now. I am still interested to hear if anyone has experienced this.
Hi, I would suggest you to verify that the data positions did not changed slightly. Maybe a data is not retrieved correctly in production mode (carriage return in it for example). Do you get the same issue with an old data file?
Yes - when I went through the logs. Everything was as it should be. At first I thought maybe the data files were getting picked up to fast. But if that was happening wouldn’t it produce an error instead of a bad pdf?
