Hi All
I’ve seen a similar error on a couple of other posts but this seems unusual as it’s only one case that seems to be a problem. The same template is otherwise working just fine and there are no problems with any others.
Has anyone got any pointers or experienced this, it doesn’t appear to be a data issue but I’m struggling to narrow down where to look as it feels like it must be case specific in some way.
Steps I’ve taken
Tried data in the template locally - all fine
Run the data through the workflow dubugger - all fine
WPROC: Originations_010B5YJNM423U9D (thread id: 15004) - 9:40:08 AM
INFO : 09:40:08.361 [0002] File processed : job010B5YJNM4X5OA4FAB98E53.dat, size: 366560 bytes
INFO : 09:40:08.361 [0002] Plugin Change Emulation completed successfully - 9:40:08 AM (elapsed time: 00:00:00.001)
INFO : 09:40:08.407 [0003] JobInfo/Variable %{JobType} is set to “Submitted”
INFO : 09:40:08.407 [0003] JobInfo/Variable %{Document} is set to “TEMPLATE”
INFO : 09:40:08.407 [0003] Plugin Set Job Infos and Variables completed successfully - 9:40:08 AM (elapsed time: 00:00:00.046)
INFO : 09:40:08.408 [0004] ConnectJson is equal to Connect: false
INFO : 09:40:08.408 [0004] Condition result is false
INFO : 09:40:08.408 [0004] Plugin Text Condition completed successfully - 9:40:08 AM (elapsed time: 00:00:00.001)
INFO : 09:40:08.409 [0016] ConnectJson contains ConnectJson: true
INFO : 09:40:08.409 [0016] Condition result is true
INFO : 09:40:08.409 [0016] Plugin Text Condition completed successfully - 9:40:08 AM (elapsed time: 00:00:00.001)
INFO : 09:40:08.545 [0017] File processed : job010B5YJNM4X5OA4FAB98E53.dat, size: 366664 bytes
INFO : 09:40:08.545 [0017] Plugin Search and Replace completed successfully - 9:40:08 AM (elapsed time: 00:00:00.136)
INFO : 09:40:08.591 [0018] JobInfo/Variable %9 is set to “TEMPLATE”
INFO : 09:40:08.591 [0018] Plugin Set Job Infos and Variables completed successfully - 9:40:08 AM (elapsed time: 00:00:00.046)
INFO : 09:40:08.626 [0019] Plugin Translator completed successfully - 9:40:08 AM (elapsed time: 00:00:00.035)
INFO : 09:40:08.627 [0020] Starting conversion of XML to JSON
INFO : 09:40:08.867 [0020] Plugin XML/JSON Conversion completed successfully - 9:40:08 AM (elapsed time: 00:00:00.241)
INFO : 09:40:08.867 [0021] Source data is a JSON string
WARN : 09:40:08.913 [0021] Cached version not available, attempting to upload file.
ERROR: 09:40:09.120 [0021] W3001 : Error while executing plugin: HTTP/1.1 500 LoggedApplicationException: There was an error running the content creation process caused by NullPointerException: (SRV000022)
ERROR: 09:40:09.120 [0021] Create Print Content: W1603 : Plugin failed - 9:40:09 AM (elapsed time: 00:00:00.253)
ERROR: 09:40:09.120 [0022] W3001 : Error while executing plugin: W3886 : Metadata file to append: “C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Spool\010B5YJNM4X5OA3.tmp\job010B5YJNM4X5OA4FAB98E53.dat.meta”, was not found
ERROR: 09:40:09.121 [0022] Create Job: W1603 : Plugin failed - 9:40:09 AM (elapsed time: 00:00:00.000)
ERROR: 09:40:09.122 [0023] W3001 : Error while executing plugin: W3886 : Metadata file to append: “%s”, was not found
ERROR: 09:40:09.122 [0023] Create Output: W1603 : Plugin failed - 9:40:09 AM (elapsed time: 00:00:00.001)
INFO : 09:40:09.122 [0024] Deleting file : job010B5YJNM4X5OA4FAB98E53.json, size: 208164 bytes
INFO : 09:40:09.122 [0024] Plugin Delete completed successfully - 9:40:09 AM (elapsed time: 00:00:00.000)
INFO : 09:40:09.122 [0024] Second execution.
INFO : 09:40:09.133 [0024] File sent to HTTP Server : C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\soap\Print\STemp010B5YJNQQDSE9DFAB99160.txt, size: 208164 bytes
INFO : 09:40:09.133 [0024] Plugin response Input SOAP completed successfully - 9:40:09 AM (elapsed time: 09:40:09.133)
WPROC: Originations_010B5YJNM423U9D (thread id: 15004) complete - 9:40:09 AM (elapsed time: 00:00:00.773)
