Workflow crash
Hi I’m running workflow version 8.5, I’ve deleted a step from a process I was testing workflow then crashed and I cant restart, any ideas please?
thanks
Alex
Do you mean the actual Workflow configuration application will no longer open? If so, try resetting the UI by holding the CTRL key after clicking to open Workflow.
Close the workflow configuration via task manager.
Then hold CTRL +SHIFT keyy while restarting the Workflow and keep the CTRL+SHIFT keys pressed until the configuration opens.
Hi thanks for your message, schoolboy error by me, made a change in debug crashed it, had to stop it in task manager and restart.
Thanks Rod, job done.
