Workflow 8 Crash - Class not found
Whilst configuring Workflow 8 on a test server i got an application error
On restart of the software i get this
Crash Dump - PlanetPress Workflow - Exception occurred on 2017/03/16 11:56:24
PlanetPress Workflow Version 8.6.1.11588
Error message: Exception EClassNotFound in module rtl60.bpl at 000290D6.
Class not found.
ExceptAddr: 4002A0D6
hInstance: 00400000
VirtAddress: 3FC290D6
Unit:
Proc:
Line: 0
Call Stack:
[4002A0D1]{rtl60.bpl } Classes.TClassFinder.GetClasses + $C1
[4002A15F]{rtl60.bpl } Classes.FindClass + $13
[00606875]{ppwcfg.exe }
[0060BDE3]{ppwcfg.exe }
[0060BC22]{ppwcfg.exe }
[0060B314]{ppwcfg.exe }
[0060D3A9]{ppwcfg.exe }
[006E7D56]{ppwcfg.exe }
[400EDDA1]{vcl60.bpl } Forms.TCustomForm.DoCreate + $31
[0063FE11]{ppwcfg.exe }
[007267CE]{ppwcfg.exe }
2 more application error screens then this
Error opening directory for watching: The system cannot find the path specified
I tried to repair the application, rebooted the server and have also tried an uninstall and re-install, same problem
The workflow file is backed up and works ok on another machine
Thanks for any help!
Hi solarcarrot,
You just need to close the Workflow, click on Ctrl key, start the Workflow as Admin and hold down Ctrl Key until it is fully opened.
Thanks very much, all good now, magic!!
Can you shed any light on why this happened? Thanks
The fix provided by yann resets the Workflow’s display settings to their default value. Therefore, I would guess that the last time you successfully used Workflow, you were using a different configuration for your monitors (multiple monitors, different resolutions, different display driver, etc.). Workflow stored those last settings, tried to use them again today but ran into some sort of error.
In any event, it’s related to the display parameters.
