What's the minimum reccomended polling interval for the API endpoints getProgress?
Once a task is submitted to the server through API the only way to know the progress is to poll the getResult endpoint of a service.
For an on demand application (or as close as possible to real-time) what’s the minimum polling interval we can use before ddosing the connect server? :sweat_smile:
If we submit N tasks and then start polling their status is there a recommended approach?
That’s an excellent question. I was actually planning on writing a blog article on that topic at some point, but I wasn’t sure it would stir much interest in the community…
So the idea is to loop until the progress ratio reaches 100 (or “done”), but without flooding the server with requests for progress updates. The idea here is to introduce a delay between each request, but the trick is to automatically change that delay value in order to minimize the total number of calls, while also trying not to delay the operation uselessly.
Here’s a (relatively) simple way of doing this :
function monitorDMProgress(operationID) {
    var progressNow = 0;
    var progressBefore = 0;
    var sleepValue = 300;
    var totalCalls = 0;
    while(true) {
      progressNow = httpGetRespText("/rest/serverengine/workflow/datamining/getProgress/"+opID);
      totalCalls++;
      if(progressNow==="done" || progressNow===100) break;
      if(progressNow===progressBefore) sleepValue*=1.5;
      // Update some log or status file here
      logger.warn("Progress :",progressNow,"/ Calls :",totalCalls,"Waiting :",sleepValue);
      progressBefore = progressNow
      Watch.Sleep(sleepValue);
This function receives an operationID and monitors the progress of that operation. It initializes a loop and calls the REST endpoint. In the example above, the httpGetRespText() method is just a wrapper around XMLHTTPRequest.open("GET",...) that returns the responseText value received from the server.
If the result from the endpoint is 100 or “done”, then the script exits the loop. If not, it checks if the progress value has changed since the last call. If it hasn’t, then it increases the delay between each call by 50%. So from a default value of 300ms, the script increases the delay to 450, 675, 1013, etc.
Important: the value is only increased when the progress does not change between two calls. Otherwise it remains the same.
Now this technique is imperfect: it takes for granted that the data mapping operation is linear and that all records take just about the same average time to process. You could implement a more robust method to better determine the precise delay between each call by storing the various progress values, along with the total time spent so far, and then figure out the best value for the next delay. That would require some much more complex algorithm, obviously.
Those more complex algorithms are exactly what the progress bars in Windows use when you install new software… and you know how imprecise those can be! :stuck_out_tongue: … So I think that my method, while imperfect, gives you a pretty good overview without being too involved, and without flooding the server with requests.
@Phil I think something is missing in your function.
Shouldn’t we reset the sleepValue to 300 once we get a progressNow that is different than progressBefore?
You only need to poll through getProgress/{operationId} if you are interested in progress feedback while a job is running.
If you just want to get the result as soon as it’s available, you can go to getResult/{operationId} immediately after submitting a job. You will get a response when the job is finished or if an error occurs.
I don’t think it’s necessary to reset the delay since it’s unlikely that the job will go faster as it progresses.
In theory, you are right: we should adjust the delay with every change of the progress ratio. But as I mentioned in my original post, this would require a much more sophisticated algorithm.
So if I set my RESTy client with a timeout long enough the connect server won’t ever drop the connection from its side?
Could be an approach to the task but keeping a connection open could be more costly than polling getProgress.
Imagine I submit a thousand tasks (given a proper server with muscle :muscle:) I would then open a thousand HTTP channels and that could seriously affect the connect server I suppose. This raises another question, is there a “capacity” metric to understand when a connect server is reaching a limit on processing? Can’t add more engines endlessly.
Just dropping a backoff algorithm used at AWS
The http client library I’m using implements it: GitHub - go-resty/resty: Simple HTTP and REST client library for Go
I’ve now written an almost complete Go library to interact with the Connect server, some endpoints are missing but I’ll get there.
I can’t give you advice on how to set up your environment, sorry. Just disregard what I wrote, it was not helpful.
