As you can see in the pictures above there are many independent data. When I want to retrieve this data from the database, I have to use more than one query. I don’t know if this is possible, but it’s going to be very difficult. I will try to make datamapper with multiple ajax methods instead. Datamapper does it suit
What is the question?
Is this actually the right method I want to learn it? I would also like to receive the ajax call in a json type. However at the beginning I could not understand which data type should I choose in datamapper
Still not sure what the question is.
Are you trying to extract data from this PDF? Or are you trying to create this PDF from another type of data? If that data comes from a database, you can use a Database-type data mapping configuration and specify a custom SQL query in there. If the data comes from multiple databases, you can use Action tasks to dynamically connect to other databases.
If your data is in JSON format, you can use Workflow’s JSON-XML conversion task and send the resulting XML to the DataMapper.
In other words, there is too little information to provide you with a more precise recommendation.
How do I make a new connection with the action task and query. If I solve this, my problem will be solved
