I have a detail table set up with 9 columns for 9 of the fields in the detail table. Occasionally, there are note lines in the data that I have extracted into a different field in the detail table. When that variable in not equal to nothing, I would like that note field to span the entire length of the table so that the note lines are not broken up into columns.
Assign the respective table cell a css class (.e.g. <td class=“note”></td>)
Create a new script in the Scripts panel and set it selector to something like this: #mytable tbody td.note
Create a script that iterates over the result set
Populate the table cell with data from the respective data field.
Create a condition in this loop to set the ‘colspan’ attribute. Subsequently remove the remaining columns. The easiest solution I found was querying for the respective table cell using the nth-child selector in the parent of the current of the table cell (e.g. within the row of the current table cell).
Below a sample script. Hope this is of some help,
// iterate over the result set
// populate our table cell
var description = record.tables["detail"][index].fields["ItemDesc"];
this.html( description );
// some condition, in this check the value of a different data field.
var shipped = record.tables["detail"][index].fields["ItemShipped"];
if( shipped > 10 ) {
this.attr('colspan', 4);
this.css('font-weight', 'bold');
query('td:nth-child(2)', this.parent()).remove();
query('td:nth-child(3)', this.parent()).remove();
query('td:nth-child(4)', this.parent()).remove();
