Hi everyone,
I am looking for how to work with my own fonts.
I have incorporated them via the interface, they appear in the Resources folder “Fonts” but not in the fonts selector.
Hi everyone,
Hello lkaiser,
Please take a look at the following trick to use imported fonts in your design. In a future version they will be available in the drop-down but for the time being you need to use CSS for it:
https://learn.objectiflune.com/discourse/t/various-tips-tricks-for-connect-designer/269/1
Evelyne.
Thank you Evelyne, it works fine
I used the CSS “@font-face” instruction to declare the bold and italic versions of my font, and in the “Design” I use HTML tags < b > or < i >
Lionel
I followed the trick recommended by Evie, and can see that my custom font is beeing used in design, in preview as well when using “Preview HTML”, but the created PDF doesn’t show the correct font. It seems to show Times New Roman instead.
Did I miss something?
problem is solved.
Thanks.
Horrido,
Thomas
