Use PCL file as input in DataMapper
Hi, Group.
I’m trying to get a PCL file to show up in DataMapper, but the PCL viewer comes up blank. I’m having the same issue with PS files. PDF files seem to work fine, as do Text files and XML files.
Version is 1.4.1.34674.
Has anyone else run into this issue, or is it just me?
Thanks.
JHB
PCL and PS input modules are required to be enabled in your license. Please contact your local reseller or support team to find out more about the options in your license.
On another note you can convert PostScript to PDF in the Workflow with the Create PDF plugin in pass-through mode. The resulting PDF can then be used as a data file in your data mapping configuration.
