How can I update a Planet Press installation on a server that does not have access to the internet? Is it as simple as downloading the current installers an running them?
Thank You!
Thank You!
J_r_smith
Make sure you donwload the offline version.
Of Course! I take it that means the answer is yes.
The only issue is the Connect installer is an ISO and the workflow a ZIP. The ISO presents some challenges.
Yes is a Yes.
you can use 7Zip to unzip the ISO, so you can bring it to the server in a zip format
Thank You! I did not realize that!
May also be worth to check the notes in the online manual, which explains how to install without internet connection:
http://help.objectiflune.com/EN/planetpress-connect-user-guide/1.7/#Installation/Offline_Installation.htm
