Units of Measure
I have my default measurements for Print set to inches, in preferences. However, all elements still use pixels when placed on the Print Section. Is it possible to change the default unit of measure for Print Sections, or Connect-wide?
What version are you on? Are you working with an old template made in a previous version?
In Connect 1.8 I just opened a new template and added some elements to the page. They were all using my default measure of millimeters
I then switched my default to inches and as I clicked on each element, the display was updated to show inches. New elements also used inches.
Elements I tested with were DIVs, Barcode boxes, and image boxes. Perhaps you’re seeing this behaviour on a different element?
Do note, no matter what your preference is set to, you can still use any supported measurement type in any field.
