Translate date in Spanish
How can I edit this script to translate in Spanish when the data field in long date format. This script work for the only if the date field in short date.
function add(value, operation) {
if (value === undefined || value === “”)
return;
operation(value);
function spanishDate(d){
var monthname=[“Enero”,“Febrero”,“Marzo”,“Abril”,“Mayo”,“Junio”,“Julio”,“Agosto”,“Septiembre”,“Octubre”,“Noviembre”,“Diciembre”];
return d.getDate()+" de “+monthname[d.getMonth()]+” de "+d.getFullYear();
var format = new TextFormatter(locale);
var result = “”;
add(record.fields[“CurrentMonthDue”], function (value) { result += spanishDate(value); });
results.html(result);
Hi, try this:
var d = record.fields.CurrentMonthDue;
result = d.getDate()+" de "+monthname[d.getMonth()]+" de "+d.getFullYear();
Katie,
You don’t need that code at all! This is all built-in to Connect Designer’s Locale feature.
Take a look at the following video, the second half shows how to use the feature:
http://learn.objectiflune.com/en-us/planetpress-connect/designer/variabledata/variabledata
