Three Differents problems - XML nested tables In Datamapper - Design and tray selection in Connect
I’m trying to map an XML and I can’t extract some tables in the right form.
When I try to extract some nested tables, the datamapper take the fields from the desired table and the items from the same table nested in other items. (I attached an example because I’m not sure if clear)
You can see the problem in the attached example.
The nested table is called “clauses”. There are 3 items in this table in each “PolicyItems”, the datamapper take all Clauses-items together (the 3 from PolicyItems rec 1, and the 3 from the record 2).
And the other problem is to get access to this nested tables from the design interface.
My last problem, I can´t select different trays printing from connect.
I tested several configurations in different printers, but checking the information received from the printer, only the size is received . I’m using Konica Minolta 951, and selecting Generic PS LEVEL 3 Production High Compression (DSC). I tested all the option from the model list.
And I following the suggested configuration from:
(sorry I can’t attach the file, can I send you the file to any email address?)
To attach a file, click on the hyperlink button in the Editor’s toolbar ( ), then click on the Send tab, select your file and upload it to the server. This will generate a link from which we can all download the file.
Once I have your XML file, I should be able to help you out with the data mapping part. After that, other specialists will be able to answer your other questions.
