Good Morning
I created new thread to track this inside here, maybe You will know what is wrong, because I am totally pissed off.
I have multiple detail tables created by template script:
var field, result = "";
var serviceDetail = record.tables.detailS;
var innerDetails = "";
var servicePricingDetails = "";
var serviceCustomerZO, serviceSAPO, serviceNameZO, serviceStreetZO, serviceCityZO, serviceRegionZO;
result += "<tbody>";
for (var i = 0; i < serviceDetail.length; i++)
serviceCustomerZO = serviceDetail[i].fields.Customer_ZO;
serviceSAPO = serviceDetail[i].fields.SAPO;
serviceNameZO = serviceDetail[i].fields.Name_ZO;
serviceStreetZO = serviceDetail[i].fields.Street_ZO;
serviceCityZO = serviceDetail[i].fields.City_ZO;
serviceRegionZO = serviceDetail[i].fields.Region_ZO;
result += "<tr class='serviceMainRow' data-breakable=\"\">";
result += "<td class='serviceRow' colspan='4' style='text-align: left;'>"
result += "<span id='servAddrTextID' class='serviceHeader'>SERVICE ADDRESS #: </span><span id='servAddrValID' class='Customer_ZO'>"+serviceCustomerZO+"</span>";
result += "</td>"
result += "<td class='serviceRow' colspan='5' style='text-align: left;'>"
result += "<span class='serviceHeader'>PO #: </span><span class='SAPO'>"+serviceSAPO+"</span>";
result += "</td>"
result += "</tr>";
result += "<td class='serviceRow' colspan='9' style='text-align: left;'>"
result += "<span class='serviceHeader'>SERVICE ADDRESS: </span><span class='Name_ZO'>"+serviceNameZO+"</span>, <span class='Street_ZO'>"+serviceStreetZO+"</span>, <span class='City_ZO'>"+serviceCityZO+"</span>, <span class='Region_ZO'>"+serviceRegionZO+"</span><br>";
result += "</td>"
result += "</tr>";
result += "<tr class='tabServiceTableDetHeader' data-breakable=\"\">";
result += "<td style='width: 5% !important;'>"
result += "<span>#</span>";
result += "</td>"
result += "<td style='width: 30% !important;'>"
result += "<span>DESCRIPTION</span>";
result += "</td>"
result += "<td style='width: 20% !important;'>"
result += "<span>SERVICE DATE/PERIOD</span>";
result += "</td>"
result += "<td style='width: 10% !important;'>"
result += "<span>WO#</span>";
result += "</td>"
result += "<span>QTY</span>";
result += "</td>"
result += "<span>UNIT</span>";
result += "</td>"
result += "<span>RATE</span>";
result += "</td>"
result += "<span>AMOUNT</span>";
result += "</td>"
result += "<span>*</span>";
result += "</td>"
result += "</tr>";
innerDetails = serviceDetail[i].tables.detailDetails;
for (var j = 0; j < innerDetails.length; j++)
var indicator = innerDetails[j].fields.Indicator;
var numItem = innerDetails[j].fields.LineItem;
var description = innerDetails[j].fields.ServiceDescription;
var containerLocation = innerDetails[j].fields.ContainerLocation;
var settDateA = innerDetails[j].fields.A_SettDate;
var settDateB = innerDetails[j].fields.B_SettDate;
var singleServiceDate = innerDetails[j].fields.SrvDr1T;
var woNumber = innerDetails[j].fields.WR1WorkOrderNumber;
var targetQTY = innerDetails[j].fields.TargetQty;
var targetUnit = innerDetails[j].fields.Salesunit;
var targetRate = innerDetails[j].fields.Rate;
var netAmount = innerDetails[j].fields.FinalNetAmount;
var dcIndicator = innerDetails[j].fields.DCIndic;
var noChargePerContract = innerDetails[j].fields.NoChargePerContract;
var tax = innerDetails[j].fields.Tax;
var serviceDate = innerDetails[j].fields.FinalServiceDate;
var asterisks = innerDetails[j].fields.AsteriskField;
// extract additional fields for extended detail line
var woInteractions = innerDetails[j].fields.WorkOrderInteractions;
var woPoNum = innerDetails[j].fields.WOPO;
var scTicNum = innerDetails[j].fields.ScTicNo;
var scaleTTime = innerDetails[j].fields.ScaleTTim;
var truckNum = innerDetails[j].fields.TruckNo;
// DP fields
var serviceDescription = innerDetails[j].fields.ServiceDescription;
var slsUnDs = innerDetails[j].fields.SlsUnDs;
var serviceRate = innerDetails[j].fields.Rate;
var seriviceNet = innerDetails[j].fields.Net;
var seriviceDCIndicator = innerDetails[j].fields.DCIndic;
result += "<tr class='detailRecord' data-breakable=\"\">";
// if record indicator = "DH" then display other record mapping with continer location and other styling
if(indicator == "DH")
//containerLocation = "TEST CONT";
if(containerLocation.len == 0) {
containerLocation = " ";
result += "<td class='containerRow' id='containerLocID' colspan='9' style='width:7.37in;'>"+containerLocation+"</td>"
if(indicator == "DP")
//serviceDescription = "TEST SERVICE";
if(serviceDescription.len == 0) {
serviceDescription = " ";
result += "<td class='detailPricingContainer' id='dp1ID'></td>";
result += "<td class='detailPricingContainer' id='dp2ID'>"+serviceDescription+"</td>";
result += "<td class='detailPricingContainer' id='dp3ID'></td>";
result += "<td class='detailPricingContainer' id='dp4ID'></td>";
result += "<td class='detailPricingContainer' id='dp5ID'></td>";
result += "<td class='detailPricingContainer' id='dp6ID'>"+slsUnDs+"</td>";
result += "<td class='detailPricingContainer' id='dp7ID'>"+serviceRate+"</td>";
result += "<td class='detailPricingContainer' id='dp8ID'>"+netAmount+"</td>";
result += "<td class='detailPricingContainer' id='dp9ID'></td>";
if(indicator == "D")
result += "<td class='detailRow' id='detNumItemID'>"+numItem+"</td>";
result += "<td class='detailRow' id='detDescID'>"+description+"</td>";
result += "<td class='detailRow' id='detServDateID'>"+serviceDate+"</td>";
result += "<td class='detailRow' id='detWoNumID'>"+woNumber+"</td>";
result += "<td class='detailRow' id='detQtyID'>"+targetQTY+"</td>";
result += "<td class='detailRow' id='detUnitID'>"+targetUnit+"</td>";
result += "<td class='detailRow' id='detRateID'>"+targetRate+"</td>";
result += "<td class='detailRow' id='detNetAmountID'>"+netAmount+"</td>";
result += "<td class='detailRow' id='detAsteriskID'>"+asterisks+"</td>";
// this will be displayed if extended fields for D record will be present
if(woInteractions.length > 0)
var scaleTicketNum = innerDetails[j].fields.ScTicNo;
var scaleTicketTime = innerDetails[j].fields.ScaleTTim;
var truckNumber = innerDetails[j].fields.TruckNo;
result += "<tr class='separatorRow' data-breakable=\"\">";
result += "<td class='detailRow' style='padding-left: 44px;' colspan='9'>";
result += "</br>"+woInteractions+"</br></br>";
result += "<strong>WO PO#: </strong>"+woPoNum+".</br>";
result += "<strong>SCALE TICKET #: </strong>"+scaleTicketNum+".</br>";
result += "<strong>SCALE TICKET TIME: </strong>"+scaleTicketTime+".</br>";
result += "<strong>TRUCK #: </strong>"+truckNumber+".</br></br>";
result += "</td>";
result += "</tr>";
result += "</tr>";
innerDetails = "";
var orderType = serviceDetail[i].fields.OrderType;
if(orderType.length > 0)
// order service row displayed if field OrderType not empty for each service
// at the end of the box
result += "<tr class='serviceOrderRow' data-breakable=\"\">";
result += "<td class='serviceOrderCell' style='padding-left: 12px;' colspan='9'>"+orderType+"</td>";
result += "</tr>";
orderType = "";
// Service pricing surcharges lines for each service from SP details lines
servicePricingDetails = serviceDetail[i].tables.detailSP;
if(servicePricingDetails != null)
for (var k = 0; k < servicePricingDetails.length; k++)
var serviceDescription = servicePricingDetails[k].fields.ServiceDescription;
var serviceNET = servicePricingDetails[k].fields.ServiceNET;
result += '<tr class="serviceSurcharges" data-breakable=\"\">';
result += '<td style="padding-right: 10px;" id="surchargeDesc" class="serviceSurchargesRecord" colspan="6">';
result += serviceDescription;
result += '</td>';
result += '<td style="padding-right: 10px;" id="surchargeNet" class="serviceSurchargesRecord" colspan="3">';
result += serviceNET;
result += '</td>';
result += '</tr>';
// do not remove this record, this is separator empty row between service tables
result += "<td class='separatorCell' colspan='9'> </td>"
result += "</tr>";
serviceDetail = "";
result += "</tbody>";
results.html(result);
Also have one Invoice section which contains following html code inside source:
<!-- All details lines of main table -->
<table id="dynamicTableServiceID" class="table--sliced" data-column-resize="" data-detail="" cellpadding="0" cellspacing="0" style="width:7.37in; margin-left: 0.18in !important; overflow: hidden;">
<tbody>
<tr>
<td style="width: 100%;"></td>
</tr>
</tbody>
</table>
<!-- No charge per contract message -->
<table id="bottomNoChargeID" style="width:7.37in; margin-left: 0.18in !important;">
<tbody>
<tr>
<td><span id="nochargeID" class="footerMessage">** No Charge per contract placeholder</span></td>
</tr>
</tbody>
</table>
<!-- Bottom HP discounts lines -->
<table id="finalTableFooterID" class="bottomFooterTable" data-column-resize="" data-detail="" cellpadding="0" cellspacing="0" style="width:7.37in; margin-left: 0.18in !important; overflow: hidden;">
<tbody>
</tbody>
</table>
<!-- Final summary inside invoice footer -->
<table id="finalTableFooterSummaryID" class="bottomFooterTable" data-column-resize="" data-detail="" cellpadding="0" cellspacing="0" style="width:7.37in; margin-left: 0.18in !important; overflow: hidden;">
<tbody>
</tbody>
</table>
It containes other simpler tables.
My problem is that when I produce invoice which contains a lot of details, like more then 2000. The first 51 pages looks right, but then ending 5 pages contains details moved up. (Details goes up, not standing in same place)
I created OL support ticket but maybe You are able to help me please.
Adam
