Strange bugs: dissapearing boxes
I had some bugs in press connect designer recently.
  • Whenever I tried to print some of the positioned boxes suddenly disappeared in the output pdf. They were still there in the designer.
  • Sometimes positioned boxes would just disappear in the designer itself, they returned quite a bit later.
  • putting overflow on hidden in my tables had no effect, the contents just spilled over the boundaries of the table.
Everything works again now but I have no idea how these bugs were caused or how they were solved. Is there some way to deal with them.
Here’s a screenshot with the warnings I got in the messages, I’m assuming they are related to the bugs because they don’t show up anymore now they are gone.
Note that this kind of issue is almost impossible to resolve on these forums because it would require you to share all the resources you’re using (Templates, DM configs, Data) so someone could look at it. You should instead open a call with our Support team, who will be able to help you out in a more timely manner.
