Split document by Pages
Hi
I’m trying to setup a generic workflow that’s splits jobs by using “Seperate by Count”, and use a variable from workflow to name the files. However whenever I try using MetaData at either document or document.set metadata it just errors and I’m not sure what I’m doing wrong
James
Hi @jbeal84,
Can you let us know please which error messages does occur whenever you try to use metadata at either document or document set level?
I assume that you are making use of the following settings for “Separate by Count”, can you please confirm if this is correct?
Separation Options > Separate by Count:
Split [ At Exactly ]
Every [ 1 ] [ Sheets ]
