sorting with a multiple-digits integer filed
I am sorting the data with a multiple-digits integer data field. Here is a piece of the data:
289099,
380169,
2595993,
9066352,
10043133
This is supposed the correct order after sorting in Connect Designer. However, I got a different result as:
10043133,
289099,
380169,
2595993,
9066352
How can I get around with this issue?
Appreciate any suggestion and idea.
It looks like your fields are Strings. If you extracted them as numbers, then the sorting order would be correct.
Actually I tried both types, string and integer. Both ways were not working. I may try to use string type and pad zeros whenever where needs to make them the same length. Thanks for your kind response.
How exactly are you sorting those values in the Designer?
I was creating a job present, grouping the data with mailing_address_id. Those values in my previous posting were mailing_address_ids. They have the integer type in SQL database.
