Soap Input not diplaying all params
Hello
We have the trial version of PLanet Press. I am seeing some inconsistencies between documentation and Trial version of planet press. As per the documentation, we are not seeing anything on the General tab of SOAP input (Such as - Soap Action Name/output etc). All I am seeing is the ‘SOAP input’.
Is this happening because I have trial version or is this the regular behavior. Please help. Thanks
The Soap Input is meant for receiving Soap requests. All you’d be doing is defining the action name in the input. The workflow would then do all of the processing.
http://help.objectiflune.com/en/planetpress-workflow-user-guide/2018.2/Default.html#Workflow/TasksProperties/Input_SOAP.html
You’re probably looking for the Soap Client Plugin, which allows you to define the remote Soap server to communicate with.
http://help.objectiflune.com/en/planetpress-workflow-user-guide/2018.2/Default.html#Workflow/TasksProperties/SOAP_Client_Plug-in.html
This is available both as an Action and an Output in those respective containers.
Thanks for the explanation - AlbertsN
Thanks for the response, AlbertsN. I am indeed looking for Soap input. I would like planet press to be the soap server. I am developing the soap client. I would like to push base64 encoded file for the print. While I use the Soap UI, I get the following error. Could you please help me by letting me know where am I doing wrong. Thanks for the help.
