Jobs can be separated by “X” number of sheets, or by various “levels”. But I want to separate by “X” number of Document Sets. Is that possible?
If I specify a number of sheets, will Document Sets potentially be broken or are they always kept together?
(My specific Use Case is Postal “Householding”. Several documents may go to the same address. Using the Job Preset, I sort by and created a Document Set for each unique Address. Using the Output Preset, I created a Folder/Inserter DataMatrix barcode across each Document Set.
We also print a human readable sequence number above the address, and I use the Output Variables for this.
The issue is we want to split the job into about 2500 sheets per output file, but need to maintain the rolling sequence number.)
