Sending to Workflow
When I am sending a job to workflow I am getting a message Preview File has not been processed
Continue with Packing File process?
I click ok and test however my PDF is blank. I have my job creation and output preset. I even re-created them. How do I make this message go away?
What is the purpose of this? I do not need a preview
Seems Connect cannot create a preview of the template layout.
Are there more details on the error message?
Is this error with each template or just with this specific one?
No other information. It just doesn’t work.
Is this error only with this certain template? I’m sure it has to do with something weird in this template, like a path or an image, which is preventing Connect to create a preview of the template.
>> What is the purpose of this? I do not need a preview.
            Preview may be useful to check visually the selected template in workflow to be sure that you select the expected one.
Job creation and Output preset are not required to generate the preview. The main reason why preview cannot be created is that the template is corrupted. In any other case, it should generate at least a dummy preview.
Can you provide more information about the version of software and OS where the problem exists? In addition, it will be helpful to have the template file and data file that cause the problem.
@Ricoh_Glenn, when you say: I click ok and test however my PDF is blank… Which pdf do you mean? Output of workflow or preview pdf?
Windows 7
Planet Press Connect Designer 1.3.2.32220
I only get this error when I send to work flow. Not when I am creating a preview.
Can you provide the template file? I will try to replicate the error.
You can send me directly to: samsonyuka@ca.objectiflune.com
The template file has some error in it. Because of the error the “Send to Workflow…” action cannot generate a preview file.
The error in template has to be fixed before sending to Workflow.
