I am testing the workflow for my property tax project. I was using the plug-in Create Output to send the pdf files (groups) to Xerox. With about 100 records, this step alone took about 17 seconds and sent the pdf files to Xerox successfully.
Then I tried with 1000 records, it again was successful, but this step alone took about 10 minutes. Later, I tested it with about 5000 records, it seemed stuck there. After about one hour, it failed with the following error message:
W3001 : Error while executing plugin: HTTP/1.1 500 Internal Server Error LoggedApplicationException:
There was an error running the output creation process caused by ApplicationException:
Error from flattener program while saving to file C:\Users\svc51303\Connect emp\Weaverengine\3380\EW-temp-3973750524693578015\EW-flatten6133994101253816840.pdf: could not save to file "C:\Users\svc51303\Connect emp\Weaverengine\3380\EW-temp-3973750524693578015\EW-flatten6133994101253816840.pdf": A file I/O error has occurred. (SRV000042)
Not sure what caused this issue? Any help or suggestions would be appreciated.
John
