Hi All,
Please Help!(PlanetPress Workflow version 8.8.0.1x)
I have a PP Print Design and Datamapper that generates an A5 colour document. I use the All-In-One configuration to build the job, and then specify the output through WF. When it runs through the “Send to Windows Printer” step, it continuously prints the document on A4 and NOT A5. I have tried / checked:
Installed and Reinstalled the Printer Driver and confirmed the default settings are A5(when I select the printer in the “send to windows printer” connector, and select properties, it does show the default settings correctly.
Gave the user group “everyone” full administration rights on the print queue
Generated a “Preview PDF” from the WF output and confirmed the PDF is generated with the correct size
Hit Ctrl+P on the preview pdf, and then it prints correctly.
Using an Output Preset prints it fine, but this is not an option.
My solution design requires me to use the “send to WP” option. Creating an output preset is unfortunately not an option) PLEASE!
