Secure Email Output
I have a simple workflow with 3 step.
  1. folder capture
  2. excute data mapping
  3. Secure Email Output
but got the below error:-
Am i miss something ?
below is the setting in secure email output
thanks in advance.
When I have this result, it is because I forgot to run my Startup process which initialized many global variables for me, which I use in my Secure Email Output plugin.
Si I am guessing that you are using variables as well in some field of the plugin and the value they contain causes this error.
Try in in debug mode and add a breakpoint on your Secure Email Output plugin. Then before proceeding with that one, look at the content of all variables you use in it, from the Debug Information bottom-right tab.
Let me know if that help.
thank you for your reply,
i didnt setup any variables for this process,
When I change the output to a folder, there is no error message.
Which version of Connect are you currently running? I haven’t seen that Secure Email output plugin icon for a long time.
The current one has a lock image instead of the SSL red word on it.
And what about the OnError tab…what’s on it?
At this point I suggest you open a technical support ticket through our website. A technician will be able to remote at your site and try and reproduce your issue.
I don’t think I can help you more without actually have access to your setup and doing some testing.
