Secure email messages
Hi - we use a secure email service where we place a keyword in the subject line and compose the email accordingly. When the recipients receive the email they need to login to view the email. I have set up the secure email plugin to test this and it sent the email but was not through the secure process. I do need to use the email content in designer so I also tried it using the create email plugin. Do you know if this is possible?
Thank You
Hi @ahaddad,
Can you please explain what you mean by “through the secure process”? Are you for example not able to “place a keyword in the subject line”?
I can place a keyword in the subject line but when the recipient gets the email it is just a regular email. We go through Cisco Secure Email Service. So when the keyword is used the recipient will get an email instructing them to login in using a user name and password. then they will be able to open the email. Hope this helps.
