saving pdf using metadata
The task to perform is as follows:
Input data = a PDF
make a filename
put filename on document
save document using filename
So far i have done the following:
in datamapper add an extract step using javascript
fieldname = filename
script =
var result = ‘1234.pdf’;
result;
In designer:
added @filename@ on top of the page
replace text @filename@ with field filename
the preview now shows 1234.pdf
made a job creation preset
check box include metadata
made a document tag with
tagname = xyz
sourcetype = field
source = filename
made an output creation preset
model = generic pdf
type = directory
output mask = ${document.metadata[‘xyz’]}
When i make a print in designer using both presets i keep getting the error:
invalid expression ‘document.metadata.[‘xyz’]’ at line 1, column 3 in pattern ‘${document.metadata.[‘xyz’]}’
must be doing somthing wrong, any ideas
Hi Gert Schievink ,
${document.metadata[‘xyz’]} should be ${document.metadata.tagname}.pdf. And be sure to select Separation in the output presets print options page. Then in Separation Option page select Document next to Separation under Separation Settings.
Thanks, that did the trick
