Resize of column not possible since update to 2019.1.0
on friday last week we updated our PlanetPress Connect System from 2018.1 to 2019.1.0.5
In the workflow-process all is working without problems.
But when I open the template in the designer, the width of the colomuns (screenshot), has been changed, and I can only edit the size of the last three columns.
In workflow and in the actual output the column “Artikel” is much wider, a the Art.-Nr. column is smaller.
Both columns can not be resized.
The table is detailed-table
Where can I look in the html-code, to resize the column again?
NBecker
Thanks for reading, the problem is solved now.
The problem was the header of the table, I delete and put them in a normal table.
After that I am able to resize the columns as I want.
Just asking… for science. Did your header row have merged cells?
The header row consists of two merged cells #Re# and Seite {#} von {##}
Regards
NBecker
Yeah, if a table has merged cells one cannot resize columns. At least that has been my experience.
Can a OL employee advise on this? I would prefer not having to delete entire rows in order to change column widths. I would prefer the same effect that an Excel table has with merged cells.
The solution with the normal table works for us, but only when there more than 1 page, the header is only shown at the first page.
Is it possible to show this table on every page, if there are more than one page?
With the master-page it does not work as we wanted, because we can not set left and right margin in the master-page.
And if I take the header in the table, I am not able to resize the columns.
Regards
NBecker
