It its possible to Pull Record.Details one by one in Template?
When i tried the pull the records in the templates it says need to use ddynamic table…
Hi @ggan,
I assume that the following message is shown when you try to drag-and-drop the record field “TOTTAX
” from the Data Model pane into the Workspace pane of the Connect Designer application, can you please confirm if this correct?
Regarding your question, can you please some more information? Can you for example explain why you would like to add the marked record fields one by one to your Template? Would you like to add them to a existing table element, for example?
