Reading data from inside XML
Hi, I created a workflow that converts XML to PS. In PS output, I want to get the name of a specific tag in XML. How can I do that? The name of the file must be tag
“<ResellerInfo
<CompanyEmail…</CompanyEmail
<CompanyFax…</CompanyFax
CompanyName>File_Name</CompanyName
CompanyPhone1>…</CompanyPhone1
<ResellerInfoLabel…</ResellerInfoLabel
Hi, you would have to add metadata in the job creation presets. Then you can use it in the job output mask.
Here is a link that explains the possible output variables:
http://help.objectiflune.com/en/pres-connect-user-guide/2018.2/#designer/Output/Print/Variables_available_in_the_Output.htm
