Hi All,
I have encountered an issue while I was trying to proof print from the Template.
Attached is the screenshot and the error log.
Does anyone have any solution to this problem.
Thank you so much.
Best Regards,
Maverick.
Hi All,
Thank you so much.
Best Regards,
Maverick.
The issue occurs in the data mapper configuration that’s linked to your template. In one of your records, you are trying to read past the end of the record.
Open up your data mapper config and click on the Validate all records toolbar button (or just press Alt-V). This should point you to the records in which the issue occurs.
Note that Validate all records doesn’t actually validate all records: it only validates the number of records defined in the Record Limit of your Boundaries settings (200, by default). So if it doesn’t detect any errors, try increasing that number.
