Problems with SVG as Image
I’m using external SVG images as image files in the Connect Designer. I place the SVG image within a div box and in the preview mode everything looks fine, but in the output pdf the images are cutted on the top.
Screenshot Designer Preview Mode:
Screenshot Output-PDF:
Thanks,
Thomas
Can you upload that specific image so we can try it here?
You can download that image here.
I have reproduced the error and escaladed it to our R&D department. Will keep you informed.
It has been confirmed a problem by our R&D department. They will work on a fix for a future release. Unfortunately, there is no workaround at this time unless you are able to remove any spaces next to the image inside the SVG.
