I am having problems with a template when updating to the version of Connect 1.7.1.44448. When I print in PDF format, the tables that I have inside the template do not respect its size. The entire template is enlarged and decompressed. In the previous version this did not happen and printed the PDF correctly. Can it be a problem with text boxes or tables?
I’m not aware of this specific issue with connect 1.7.1. We’d definitely like to look at this in much more detail then can be done over the forum so I’d recommend you open a support ticket with you local team.
Alex Banahene
