I am trying to use new font inside Connect designer to build document template.
The font is ‘Helvetica.ttf’
Font is installed in Windows system, its also visible from designer fonts drop down window.
The font in designer looks good, but when I render PDF and open it, there is no Helvetica font inside, it has been replaced to other font types like ArialMT
I tried also to use css to apply Helvetica or add Helvetica.ttf inside Fonts/ directory but still no effect.
Then I suggest you open a technical support ticket through our website. Make sure to upload you TTF file and a technician from support will help you with this.
The 14 base PostScript fonts, especially Helvetica, are handled differently than other fonts. Adobe Acrobat does the same thing. Perhaps you are seeing an adverse effect of this.
Creating a support ticket is the right move, as we will be able to take a closer look at this.
