Problem with Execute Data Mapping
Good Morning
I am creating Connect project where and I am facing some problems with Execute Data Mapping plugin.
I received following errors:
  • “W3001 : Error while executing plugin: HTTP/1.1 401 Unauthorized”
I have default Connect Server configuration:
user: ol-admin
password: secret
Also my Connect REST API using same user name and password. Still not working.
Also tried to disable Server Authentication and nothing. Process hangs on this plugin instead of throwing error.
Please help.
Ok sorry, I solved this problem.
The rootcause of this issue was that I had to also set proper credentials inside Workflow preferences OL_Connect tab
I have the exact same problem and I try to figure out how you fixed your problem ? I cannot find where is the preferences OL_Connect tab ?
Could you help please ?
Go on the big W button in the upper-left corner and chose Preferences then Behavior and OL Connect. There you can set your User name and Password.
They must match exactly those of your Connect server configuration.
If there is a value in your Workflow Preferences, then it must be turned on in your Connect Server configuration.
It is simple:
Turned on in Connect server Configuration = Value in Workflow
Turned off in Connect Server Configuration = No value in Workflow
I’ll check that tomorrow, thanks for the quick answer.
It’s work, thank you.
