Printing Question
I am printing to ID Card printers. The forms were developed in Planet Press Suite Designer and imported to the Planet Press Connect Workflow 8.5 on a Windows 2012R2 server.
The card printers (Datacard use a standard ID card size - ISO ID-1. This is not a size option in Designer so I set the form to custom and enter the page sizes - 5.3980cm and 8.56cm. It is interesting to note here that the Planet Press Suite Designer form converts 8.56 to 8.5601 automatically.
When the form is sent to teh printer I get the following warnings in the Workflow log:
WARN : 15:14:08.947 Page “$SCHWENDEN_B” is not of a supported page size by the printer driver
WARN : 15:14:08.948 Page “$ClearVars” is not of a supported page size by the printer driver
WARN : 15:14:08.948 Page “$SetVars” is not of a supported page size by the printer driver
“$ClearVars” and “$SetVars” are not even set to eject. Are these just because I am using a Custom Paper size in the form?
By teh way - I am using the “Print using a Windows Driver” output.
Thanks!
If the data is not sensitive, can you post your template, datamapper and data file on here?
If it is, if you have OLCare, open an issue either on ourweb site as follow:
To upload your documents:
  • Go to our Website: www.objectiflune.com
  • Go to the Support menu
  • Select PlanetPress support
  • Scroll down until you see a black banner that says “Report an issue”
  • Follow the procedure.
or contact us at 1-866-348-5863 to open an phone issue.
Here you go!
As previously mentioned these are PP7 docs imported into the Connect Workflow.https://learn.objectiflune.com/qa-blobs/6934997033093389259.bak
